Importe 3D model Drawing
hello....
I am exporting 3D drawing (Cabinets Drawing) from 20/20 Design to Autocad 2006 and the drawing that I got in Autocad is whole a block,,,How can I unblock without explote the 3d drawing so I can make some modifications...
thanks for your help in advance...
RE: Importe 3D model Drawing
did You try "_explode"? Normally, the objects inside the block are not exploded.
If You want to obtain the block, use "_refedit".
L.
ADT 2004
ACAD 2002
thanks so much....
type "_list" and the click on an object. What is ist? A block or a group?
Lothar
ADT 2004
ACAD 2002
