Storage elevation flow relationships
When doing a reservoir routing with Hec Hms, I need a storage-elevation-flow table. I got my stage-flow relationship from my (already modeled) Hec Ras Stage rating curve at the station at the upstream face of the bridge. Is this correct? At each height, I can see a corresponding flow. Can't I use that as my outflow from the bridge?
Also, I wanted to use cumulative storage from HEC RAS as my storage data, but that doesn't seem to be working. I took the total storage at the upstream-most cross section and subtracted (the cumulative storage at the upstream face) from it. I used the total storage from the channel+LOB+ROB. Something must be wrong because when I run those values in HMS, I get an increase in outflow which isn't possible, is it?
What is the best way to obtain the storage upstream of the bridge?
RE: Storage elevation flow relationships
