electronic valve search
hi im looking for a electric or electronic valve to control propane gas flow. low psi
regards
killa
RE: electronic valve search
How large or small is the line?
Is this for on/off or throttling?
Pneumatic force is normally used within the process industry to move the valve and an electrical signal is used to throttle or switch the pneumatic medium such as an instrument air supply.  Solenoid valves can switch the air for on/off applications.  For small valves, perhaps less than one-inch, solenoids operate the valve directly.  Hydraulic fluid is used for very large forces.  Electical motor operated and self-contained electro-hydraulic actuators can control valves where no air supply exists.
Fisher (look for Emerson Process/Fisher-Rosemount, etc.) is among the leaders with good stuff  such as a "Control Valve Handbook" on the web.
John
but i dont know how to deliver 30% or 50% or 90% off the gas valve using a solenoid one.
the valve is less than one inch.
how fast can i turn on and off such a solenoid to achieve PWM control?
regards
killa
Maybe try contacting an electronic actuator manufacturer (e.g. Rotork, EIM) to see what sizes of actuator they have that would be suitable for your valve.
If you could figure out how to use a 24Vdc 3-way, 2-position solenoid valve for compressed air or inert gasses from 28" Hg vacuum to 125 psig pressure, here's a bargain I noticed a few days ago: <allelectronics.com>  CAT# SV-4
If you don't have instrument air, you can always use propane. We often do at remote sites.
sorry, so im looking for an electronic or electric actuator and not a electronic valve.
what do you mean with instrument air?
i will use low pressure propane.
thanks, im aiming to what i need
killabyte
A valve is a piece of metal, plastic, other material, that is in a pipe/line, and provides a "restriction" to flow.
When people say electric valve, it is usuall taken to mean an electric actuator on a valve. An electric actuator uses electricity to move/stroke a valve.
An alternative is to use a pneumatic actuator. In which case, air (or N2, fuel gas, etc.) is used to move/stroke the valve instead of electricity.
thanks fopr your help, ill start loking for electric actuators for propane gas purposes.
regards
killa
There is a company out there that does little BUT gas valves.  Here is a link:
http://www.maxoncorp.com/gas-valves.html
Seems like every time I walk up to a package boiler it is festooned with Maxon valves.  I have no affiliation or specific experience with these guys, but installed base speaks to their success.
