GD&T Control frames & Dimension Lines
I've noticed that when I place a control frame on a diamter dimension (Side view), the dimension line runs through the control frame.
Is there a way to eliminate this?
RE: GD&T Control frames & Dimension Lines
Check out CATBlog!
I remember this happening with basic dimension prior to R11, but not since.
Suggest submitting a PMR (once you check for an existing) if it has not been fixed by service pack. It could have been broken by a particular service pack or hotfix, if you are using something other than the basic release.
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog
