SW ICONS
SW ICONS
SW ICONS
Does anyone have a list of icons in SW 2005 and their meaning. I have an icon in my tree that im not exactly sure what it is. I think it represent a configuration part.
RE: SW ICONS
I have been!! Cant find the icon
RE: SW ICONS
The icon looks like a typical part icon, but its in a trimetric view with a green square smaller then that of the one used for assembly icon and shifted up slightly.
RE: SW ICONS
It's an assembly which has been set to "flexable"
RE: SW ICONS
Describe the icon or show an image.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
RE: SW ICONS
Thanks, But would still like to have list if anyone has one.
RE: SW ICONS
The easy way to do this is to edit your toolbars.  Right click your menu area, select toolbars, select the toolbar/features/whatever tab.  When you hover over the various icons in each category (or click one) they tell you what they mean.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
RE: SW ICONS
I think some of us are being thrown by the word "icon," which most users associate with a toolbar icon. From what I can tell this is one of the Feture tree icons like part, assembly, axis, mate, etc. MElam seems to have identified it, but I don't know of a list of such icons anywhere in SW.
RE: SW ICONS
In the Help, go to the Index, and type "Flexible".  At the bottom is the symbol for Flexible Subassembly you seem to be talking about.
To get a list of feature/function toolbar icons, you can go to Tools, Customize, Command, and get tool tips that show you what they are.
Also if you look in Help under the name of a Toolbar, it lists all the available toolbar icons for that toolbar, with pictures and names.
For other icons, look in these areas of the Help:
- Feature Manager Design Tree
- Icons, Feature Manager
- Assembly, Feature Manager Design Tree
RE: SW ICONS
Searching the help works best if you spell flexible correctly like dezignstuff did - instead of using my spelling purpleface
RE: SW ICONS
Search help for "Toolbars". SW will provide all the available toolbars. If you click each link individually you can see all the available commands with respective icons associated with the commands.
RE: SW ICONS
Unfortunately there is no definitive-all-in-one list supplied with or by SW (that I've found). The icons/symbols/conventions used are scattered throughout the Help files ... and unfortunately you have to know what the icon represents to be able to look it up. Kind of defeats the object, 'coz if you knew what it was you wouldn't need to look it up in the first place!
You could wade through the Help files & compile your own list, but it sure would be nice if SW supplied it. At the very least a "What's this" button would help.
cheers
