Sheet Metal Weldment?
I'm trying to create a weldment made up of several cut sheet metal stampings then mig-welded together. Is there a way to build a sheet metal weldment within a .sldprt environment? It appears SW only allows one sheet metal profile within a part file. Im trying to avoid creating multiple part files and combining it in a .sldasm file.
I use the weldment features all the time, but this is the first time I’ve come across a sheet metal issue.
Im using sw06 sp3
thx,
pj
Im using sw06 sp3
thx,
pj
RE: Sheet Metal Weldment?
I have found it is usually much easier to create the assembly file than to avoid it.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP3.0 on WinXP SP2
