Linking dimensions to notes in DRW
Does anyone know how to include two dimension in a note. It could be something like NOTE: c'bore dim 1 depth dim 2. I know c'bore can be done another way but it is a simple example.
In ProE the & symbol acheives this function.
Kevin
Kevin
RE: Linking dimensions to notes in DRW
Thanks for the quick reply.
Your suggestion revealed a weekness in my question. Is it possible to add a dimension to, say, an existing hole diameter dimension?
Kevin
Can you explain better, or show an image?
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP3.0 on WinXP SP2
I have done something similar by adding a note linked to the dims, then delete or hide the originals. I did it to get a radius dim to attach to a multi-jog leader.
Of course. My pet peeve example:
How many times have you had a blind bore or pocket and then for the depth you had to add an "As Shown" or something like that where the machinist would have to find some other dimension to get the depth. Wouldn’t it be nice to have all that info in one spot?
Or maybe a stepped hole? This would allow you to form a custom bore/depth callout with multiple diameters and depths.
Ken
Spot face dims
Rough bore cavity dims
Cavity detail dims
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
