where to install pro-e
would i be better off setting up pro-e on an external hard drive so i could take it with me from home to office?
is there any license issues with this?
i do not have up to date maintnance with ptc
RE: where to install pro-e
If you put it on an external drive and transfer from machine to machine, it wont find the original cpu-id. If you have floating licenses on both home and office machines, then you may be ok.
Steve
http://www.sprdesign.com
http://www.3dlogix.com
Be sure to install Pro/E with no spaces in the path name. Certain functions still don't work properly if you install in C:/Program Files. PTC has been trying to fix this for haow many years?
http://www.globes.com/support/flexlm_index.htm
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
