BOM ITEM #ing
BOM ITEM #ing
I am using the SW BOM as opposed to the Excel-Based BOM. I like some of the features of it.
My problem is that when I select INDENTED ASSEMBLIES and SHOW NUMBERING under BOM OPTIONS it shows the item number for the indented items in "outline" format. Is there a way for it to treat them in the sequence of item numbers? i.e. instead of:
1
2.2
3
to be:
1
4
5
I would like to stay with the SW BOM if I can instead of Excel-Based.
Thank you for any help here
1
2.2
3
to be:
1
4
5
RE: BOM ITEM #ing
RE: BOM ITEM #ing
Just kidding - glad you found the fix to your issue!
support69
RE: BOM ITEM #ing
