Plotting Autocad 2k
Plotting Autocad 2k
Have one of the guys here in the office asking me plotting questions about Autocad 2k, (I'm still not very familiar with the changes from 97, and I'm also running LT). The problem he's running into is, when he brings up the plot dialog, it defaults to selected tab, instead of current tab. He says it didn't do that before, just started this morning. If this a setting somewhere that got changed that forces the default to "selected" instead of "current" or is this a case of user error that I haven't solved yet? Also, says when he checks "Save changes to layout" that it doesn't save them.......
RE: Plotting Autocad 2k
plot settings are not an item you want to mess with
in Autocad's new programming.
What's so difficult about that situation anyways?
and becomes known as the layout. By right-clicking
the layout tab on the lower left of the screen, you
can set that one layout to plot exactly how you want
it every time. The right-click allows you to set the
settings without plotting the drawing. It will refer
to those settings on any other computer that opens the
drawing. If those settings don't exist in another
computer, it will show.
