Partial section on assembly drawing
Anyone out there got step by step instructions on doing a partial section on an assembly drawing?
I can do the full and half sections, but what I want is a partial section through a small part of the assembly, so that I can show this at a larger scale.
RE: Partial section on assembly drawing
Another method is to create the full section, adjust the section line to area desired, then update the section view.
If you would like I can provide you some help in generating this if you would like.
Dan
