3D arc/elipse
3D arc/elipse
Is there any way to make a circle or ellipse between coordinates that are not parallel in UCS.
I'm using autodesk map 2005 but have also accsess to Autocad 2005 and ADT 2005 if that helps.
RE: 3D arc/elipse
RE: 3D arc/elipse
The problem is that I have 4 coordinates wich is not in parallel (measured with total station on site) and it is not quite a circle, more like ellipse.
So how do I draw an oval (circle/arc like) line in 3D, or between these 4 points that i've taken from the total station.
RE: 3D arc/elipse
I did a quick Google search for 3d poly lisp routines. It appears 3dutil.cip at http://www.cadresource.com/library/lisp0a.html
may be what you are looking for.
RE: 3D arc/elipse
