ezpolar, want to make the text go away
When i use ezpolar(f) a text appears right below the figure that shows the function f. I'd like to make it go away. How can I do this?
RE: ezpolar, want to make the text go away
ezpolar() is an m-file function.  The last bit of it looks like this:
text(0,-1.2*max(abs(RHO)),['r = ', texlabel(rho0)], ...
    'HorizontalAlignment','Center','Parent',cax);
Delete it.  Or if you prefer, copy the m-file locally with a different name first so you don't mangle the installation.
