I am Looking For Flow Network Analysis Software
I was wondering what types of flow network analysis software other folks here are using. We currently have Haestad Methods, but would like to get away from it. Any software out there at a reasonable price that will let you do unlimited nodes/pipes? Is anyone using HydrauliCAD? Looks cool. Any info or recommendations would be appreciated.
Thomas
Thomas
RE: I am Looking For Flow Network Analysis Software
Geoffrey D Stone FIMechE C.Eng;FIEust CP Eng
www.waterhammer.bigblog.com.au
- Data Management and Ownership of Data
- Annotation of Model Components
- Contour Plots of Model Result Areas
- Diagnostic Messaging (Error messages)
- Documentation Capabilities for Individual System Components
- Establishment of Open Links with Database Software
- Fire Flow Analysis Capabilities
- Graphing/Profiling of System Components/Model Results
- Links to Geographical Information Systems (GIS)
- Links to SCADA system
- Online Help
- Scenario Management Capabilities
- Site Layout Capabilities
- Software User Support
- Water Hammer Analysis Capabilities
- Water Quality Analysis Capabilities
- Windows Environment
- On and on and on….
Buyer beware, some of the hydraulic modeling software on the market today are NOT based on a GIS platform. Software manufacturers have HUGH differences between them, which can make a night and day difference to the Owner and the End-User. It is highly recommended, before you purchase modeling software, get the manufacturer to provide you mulitple ON-SITE demonstrations.
Do not be afraid to ask the hardball questions. Like…
- Can you run your software with only Arcview, or do you need Arc Editor or ArcInfo?
- Create a contour of pressures in an ArcView environment. In contour creation, please demonstrate creation directly on the model itself. Show the routine how to export this into a personal geodatabase
- Change from one scenario to another while each time showing how each element set corresponds to which scenario.
- Show results of multiple scenarios overlaid in an ArcView environment.
- Demonstrate how you “deactivate” facilities so that they are not included as part of a model run and are not shown on the map. Example, deactivate a sub-division. Please discuss any limitations to the process.
- Demonstrate how you automatically assign elevations from a Shapefile of elevation contours. The shape file will be provided at the demonstration.
- Demonstrate your entire suite of network review and/or fix tools with respect to connectivity. Please show both the find and fix parts. Once fixed, run the model to show new results.
- Does your software work within ArcView 9.0? Please demonstrate.
- Is there minimum database hardware requirements?
- Is there a background process that runs on the database server to perform computational transactions?
- What are the minimum bandwidth requirements? Will staff be using this software at remote sites?
- On and on and on…
Yes some software is free; however the major drawback of it compared to commercial modeling programs is the use of the text editor for data input. It also lacks graphical (GIS) input capabilities and has NO technical support.
I am an end-user not a salesman. I purposely did not state any manufacturer’s names as to which software is better than the other. (That would be way too easy.) I strongly recommend the end-user (the Owner) must ultimately do the home work.
I hope this helps.
unlimited nodes
duration analysis
controls features
quality parameter measurement
graphical interface
non proprietary data set (you can read the files with wordpad)
The only time I would recommend anything else is if you want integration with GIS or other databases
and of course as many of my colleagues say 'its free'
Hydrae
