Design Table and Hole Wizard Data
Is there a fairly simple way to reference Hole Wizard Data from a Design Table. The problem is that I have a part with many configurations. Some of these configurations have different hole properties (thread, depth, etc.). When I create a new configuration and change the hole size, it remains that constant hole size across all configs. Basically, when I change a hole size/type in one config, the hole size/type changes across all configs. So I guess my question is two-fold. How can I (either manually or automatically) keep distinct hole data for each separate config? And can I do this from a design table?
RE: Design Table and Hole Wizard Data
You can change the hole parameters, but the description in the FM tree would not reflect the actual size in the configs.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
e.g. Flange Mounting Hole rather than 1/4"-20 Tapped Hole.
