site containing military connector models
Can anyone point me to a site with solid models of military connectors? As these are the same world-wide any good site will do.
Thanx for any help you can provide
RE: site containing military connector models
There are some mil connectors in 3D Content Central in the design library.  Look under UserLibrary/Electrical/Connectors.
Timelord
I have found many connectors at the Tyco AMP site, http://connectors.tycoelectronics.com/
It is pretty clumsy compared to say, Lcom, but you can get there from here. It helps to know the AMP part number or what AMP calls the family you want to use. The models are usually good.
Hardie "Crashj" Johnson
SW 2005 SP 4.0 (reluctant to change)
Matrox Millenium G550
AMD Athalon 1.8 GHz 512 Meg RAM
3D Content Central has a good collection of MS.  I've posted a view myself.
http://www.3dcontentcentral.com
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
Thanks for the link SnowCrash (Bad skier??)
We use lots of AMP Connectors, military and others, this'll save me drawing a connector each time we use a new style.  Did find that my models are pretty close by downloading the AMP model and inserting it on top of my model.
