Print Diagram
Print Diagram
I imported a .wmf file as my diagram background and now want to print the routing diagram WITH the picture in the background. Each time I try to print the diagram, I only get the nodes (no background). How can I print both from HydroCAD. Is this even possible?
RE: Print Diagram
RE: Print Diagram
On the Settings|Diagram screen (where you selected the background image) you can specify if the image will appear on the display and/or the printed reports.
The option to frame the background image determines if the image size is considered when the software determines the overall extents of the project. Otherwise, the extents are determined only by the existing nodes, and the background image is allowed to "overflow" off the edges or the screeen or page.
