Culvert Question
Culvert Question
ALthough not a true bridge question, still hope some one can help.
I am looking for the proper culvert material to use in the following situation:
Cover = 70ft
Size = 7' dia
Environ = Marine (50 feet from ocean)
Note: emergancy situation, so a custom concrete does not work
With the extreme cover and marine enviro, do you know of a "special" HDPE that can take 70' of cover when it is 84" diameter?
Cover = 70ft
Size = 7' dia
RE: Culvert Question
More details? Where is this? OC? Sounds interesting.
The facts are correct....70' of fill on top of the pipe, and the creek that it carries is tidally influanced, and gets ocean water in the pipe......
