NEMA 4x gasket
NEMA 4x gasket
I have a NEMA 4X box that needs to have a threaded panel mount sma connector attached to the outside for an external antenna. Do I need to put a NEMA 4X approved gasket underneath this connector, or does the nut and washer constitute an appropriate seal to maintain the NEMA 4x rating?
RE: NEMA 4x gasket
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
RE: NEMA 4x gasket
RE: NEMA 4x gasket
