C-ring load equation,
Does any one know the equation for calculating the load exerts by a C-ring?  For example, a C-ring with 1.000” OD,  0.020” thickness, 0.125” width and 0.060” gap.  If the C-ring is deflected by 0.050” so that the gap now is approximately 0.010”, then what is the load?
I would like to have an equation so that I can vary the spring thickness to achieve the desired load.
Bogiedreamer
RE: C-ring load equation,
do you want load expressed as pressure, or load expressed as a force couple acting through the ring center, or load expressed as a force acting at the ring tips?  In any case, you can probably find your answer by searching online for "calculating piston ring tension."
Hi bogiedreamer
You can find your answer in most strength of materials books under curved beams using a strain energy method.
regards desertfox
Integralof M^2/2EIr*d@ from 0 to 2pi is strain energy.
where I use @ for the angle theta since I don't have Greek letters
M=Fr(1-cosine@). So
Energy=Integral{F^2*r^3*(1-2cos@+cos^2@)/EI*dtheta -limits 0 to 2pi
Since cos^2@= (1+ cos 2@)/2
This integral becomes
3pi*F^2*r^3/2EI and the deflection is the derivative of Energy with respect to F or
defl=3piFr^3/EI
This should be enough to get you to a thickness for a given force and deflection.
