Rotate with Middle Mouse Button Issue
I have an issue with an undesirable "pan" command popping up when I want to rotate with the middle mouse button.  Sometimes it doesn't happen, sometimes it does, I don't know what the deal is with this.  I ONLY want to rotate with the MMB.  I can not find a setting for this in SW. Here is an attached image of the offending cursor I am speaking of:
http://img384.imageshack.us/my.php?image=pansymbol9rb.jpg
RE: Rotate with Middle Mouse Button Issue
Turning off the itellipoint in the Control Panel appears to have done the trick.  Thanks!
