low pressure electronic gas valve
hi, im looking for a low pressure propane gas electronic valve or regulator or such a way to control the gas flow delivered to a small (20 of them) gas heater
the heater is fed by a small propane gas cylinder. im not sure about psi but one of those cylinders weights between 40 and 100 lb.
the valve should deliver flow between 0% and 100% in a smooth way so i cant use a on/off one.
the valve is used in a greenhouse and trough electronics to control temperature.
the gas use is a must.
ive been thinking about pwm controlling a on/off valve but im new to gas valves
regards
killabyte
regards
killabyte
