Faking dimensions..
Faking dimensions..
I am looking for a good way to override dimensions with text (Symbols and text).
Any suggestions?
The only way I have found is to create the dimension, then right click on it, select properties. Then I check the fake box on the value tab. Then I type in the text in the "Alphanumerical" box (If I want symbols before and after the text, I must use the "Alt + number" to insert one of them). The symbol icon does not work while changing text in this manner.
Thanks for any help.
Any suggestions?
RE: Faking dimensions..
I know that you want a more "automated" solution, so for more information on the subject, search your computer for the help document, called "driugsa0404.htm"
Hope that helps.
Check out CATBlog!
Thanks again!
