Line size on screen
Line size on screen
Line size on screen
Hi to all,
anyone knows if it is possible to set the tickness of lines on screen? I mean, I need to set "thin, normal, thick, thick(2) etc.." to have the same thickness on the screen, in particular I would like to see them all as "thin" (then i will set the line weights to plot them as I need).
It's a quite strange request, but you know, curiosity...
Txs to everybody
RE: Line size on screen
That's a DOCUMENT PROPERTY... Open a drawing. You don't find that option in part & assembly files. Click TOOLS - OPTIONS - DOCUMENT PROPERTIES - LINE FONT.
Windows 2000 Professional / Microsoft Intellimouse Explorer
SolidWorks 2006 SP02.0 / SpaceBall 4000 FLX
Diet Coke with Lime / Dark Chocolate
Lava Lamp
www.Tate3d.com
Txs,
but it is not what I need, I try to explain better the problem
If I set, for example, thin for "visible edge" and normal for "Hidden edge" I would like to see them both as thin (on the screen). But then I can plot them with two different thickness, beacause they have two different names (that I can set in "line Wehigt".
I think that there must be a file that associates the name (thin, normal, etc...) to the thickness on screen, but I can't find it, and above all...I'm not sure that I can modify it
I think with SolidWorks... WYSIWYG (What You See Is What You Get). You can look at the LINE WEIGHTS option on the PLOT dialog box... But I don't think that's what you're looking for either.
You just need to let go of your AutoCad paradigms... (It'll be OK)... tongue
Lava Lamp
www.Tate3d.com
Hey, this is Solidworks, not AutoCAD!
nosmiley
Flores
SW06 SP3.0
Txs again Tatej for your fast reply,
you know, I have always disassembled my toys...and I try to keep on doing it...
(P.S. I come from CATIA V5...I hate Autocad...)
