Sorting string from an array
I have a list of strings and I would like collect from that list only one time if the strings the same for example if an array("A", "B", "C", "A", "B", "B")
and I would like to collect ("A", "B", "C").  How do I do that.  Thanks in advance
RE: Sorting string from an array
One way would be to put the array into a collection, since you cannot have duplicate data in a collection, only those strings not equal would be in the collection.
Regg
Hi Regg,
I am kind of new to VB, I tried to collect like you suggested, can you give me sample code.
Sub Sorting()
    Dim ListString
    Dim CollList As New Collection
    ListString = Array("A", "B", "B", "A", "C")
    i = 0
    Do
        CollList.Add ListString(i)
        If i = UBound(ListString) Then Exit Do
        i = i + 1
    Loop
    Debug.Print CollList.count
End Sub
I use a dictionary to do this
Sub GetUniqueEntries()
'note add a reference to Microsoft Scripting runtime to be able to use dictionary objects
    Dim ListString, i As Integer
    Dim DicList As New Dictionary
    For i = 0 To UBound(ListString)
        If DicList.Exists(ListString(i)) Then
            Else
            DicList.Add ListString(i), ""
        End If
        i = i + 1
    Next
    For i = 0 To DicList.Count - 1
        Debug.Print DicList.Keys(i)
    Next
End Sub
Camille1,
Sorry for taking so long to answer your reply.
What I meant was that collections do not allow duplicate keys.  Try this code:
CODE
Sub Sorting()
    'declare variables
    Dim ListString As Variant
    Dim Item As Variant
    'create collection
    'create test array
    'set error routine to skip duplicate key
    On Error Resume Next
    'loop through test array
    For Each Item In ListString
        'add item to collect using item as both item and key
        'collections do not allow duplicate keys and raises error 457
        'On Error Resume Next lets program continue on with stopping
        CollList.Add Item, Item
    Next
    'turn off error handling
    On Error GoTo 0
    'display number of collection items in immediate window
    Debug.Print CollList.Count
End Sub
Regg
I learned new things from this.  Thanks to all of you
Camille1,
Just out of curiosity, how did you solve your problem?
Regg
