quiet steel
quiet steel
ford,gm,and chrysler have used "quiet steel" in dashes,cowls, plenums,engine components etc. but does anyone have information of the laminated metal being used in exterior shhet metal as in doors,hoods,trunks?
RE: quiet steel
I've seen that stuff being pushed for 25 years, it has its place, it is no panacea.
Cheers
Greg Locock
RE: quiet steel
RE: quiet steel
RE: quiet steel
danno
RE: quiet steel
RE: quiet steel
BTW, I have used "Quiet aluminum" from MSC for floor sheet in a Class 8 truck cab, on a prototype basis, and found only a very small reduction in sound transmission through the floor, due to the lack of a coincidence peak in the material. It didn't jsutify the increased expense and somewhat greater difficulty in fabrication.
- R
RE: quiet steel
