Link Property to Sub-assy Description
I'm attaching a note to a small sub-assy (a ball valve w/ an actuator on it). We call the sub-assy out as one part (3" Ball Valve w/ Electric Actuator). But when I link the note to the sub-assy's description, the only option that seems to pertain to me is to link property to "component to which annotation is attached." That only gives me the description for one part in the sub-assy.
Does anyone know a trick to make this work, or maybe I'm overlooking something?
RE: Link Property to Sub-assy Description
there should be 2 options available for you.
1.Current Document
2.Component to which assembly is attached.
and 2 other options which are greyed out.
Out of the available options select " Current Document" and link to the desired property.
Maybe I could add the note in the model and bring it in as a model item?
Also, I tried to follow the FAQ info on "BOM Wrap Text," but couldn't get the hard return to work in Excel. I have Excel 2003. Can anyone clue me in on this?
1.Current Document
2.Model in view to which annotation is attached
3. Model specifed in sheet properties
4. Component to which annotation is attached.
If you select " Model in view to which annotation is attached, you will get the desired result.
I have submitted this as an ER in the past. You should do the same.
