Pro-E Assy to STEP to UG
I've translated a STEP into UG and nothing shows up in the UG part file. It is native Pro-E and was an assembly file. It was then translated to STEP and sent to me along with the components. The components, when translated, created two .PRT files, one empty and one with the geometry... I guess what I'm asking is if anyone knows a trick to translating "cleaner" from a Pro-E Assy file into UG, please let me know. Or if there is something I'm not accounting for, pass that along.
Tim
Tim
RE: Pro-E Assy to STEP to UG
Ben Loosli
Sr IS Technologist
L-3 Communications
Thanks!
item1.stp ---> item1.prt
When I translated the assy file, it re-translated each component and sub-assy in the assy file, adding some arbitrary 'addition' to the file name....
asm1.stp ---> asm1.prt, with item1XXX.prt
The extra component file is empty, therefore the assy is empty. And after looking at it, it's more than just 5 component files with in the sub assys!!!
This is probably not real clear... but any added suggestions would be helpful. Thanks to all!!!
