Simple Pro E Question on customization
I have never used PRO/E but I am trying to write some code to pull REV numbers and some other information from PRO/E and insert it in a table.
I know in Autocad I use VBA to write code , Is there a language to code PRO/E in?
If there is a programming language , Do I need to buy an external tool kit to customize it?
I need some basic tutorials on customizing PRO/E and what version of PRO/E do I require to write code?
Thanks for the help.
RE: Simple Pro E Question on customization
Pro/E and Pro/Intralink both have a toolkit application development environment that is written in C. there is also a JAVA interface to some Pro/I functions. I suppose you could also use SQL on the Pro/I database in Oracle.
PDMLink has a JAVA interface internally, but I don't know about getting to the data from the outside, except SQL to Oracle directly.
Ben Loosli
Sr IS Technologist
L-3 Communications
