thread454-124409 a follow up
Thread 454-124409 discussed the use of a web based ventilation controller to automatically reduce ventilation at times when the mine was empty.  I'd be interested in hearing if anyone has successfully done this.
There are some massive cost savings that can be achieved by turning these fans down once in a while and I would welcome any feedback as to the pros and cons of using web-based control software.
RE: thread454-124409 a follow up
fatboy1999,
Perhaps you should join the Mine Ventilation Email List and post your question there.  You may find better responses from that group than on Eng-Tips.  Details to join the list can be found at http://free.hostdepartment.com/u/uvcsme/uvc.html
Scroll to the bottom, under Notes & Announcements.
Good Luck,
CanuckMiner
Thanks for the feedback.  I will look into it!
