Export PLINE to csv file or Excel
I have a dilema. We do alot of cnc work here and the same question always comes up 10 minutes after the programmers leave. Is this code right? Is there a way that i can take a simple polyline and export that in a x,y format with a given origin. Not concerned with the radius but just end point to end point just need it for a quick verification of what is done. And in the future the set-up guys can just go to a terminal and check it themselves. Thanks
RE: Export PLINE to csv file or Excel
The "non-programming" way would be to first set your origin
UCS>>New>>Origin>><select point>
Then do a "LIST", which will show x&y of the vertices.
