Help Needed - a vertical lift for a linear rail
We have a 10' long linear rail (~100lbs) which will have a 250lb load translating from one end to the other. The lifting device needs to cover a range of 1'6" to 3'6" and remain stable with the load at either end of the rail. Our first choice for operation would be manual (a crank, etc.), second choice would be electric and third would be hydraulic or pneumatic. The weight of the lift needs to be less than 200lbs if it is a single unit or if it is multiple pieces the total weight must be less than 400lbs with no individual piece exceeding 200lbs. If anyone has any ideas or experience on this subject please help. Thank you!
RE: Help Needed - a vertical lift for a linear rail
or something similar
(no affiliation)
Mike Halloran
Pembroke Pines, FL, USA
Barry1961
www.mcmaster.com
Are the any side forces?
What is the stiffness of the rail? Will it support the load with an acceptable deflection if it is simply supported at the ends? Cantilevered? Supported at the middle?
You can't solve a problem unless you understand it.
http://www.duffnorton.com/products/supercyl.aspx
You can add an encoder or change the motor to gain positioning accuracy. Basically it's just a acme screw and gearbox. (which you could design yourself if you want, but why?)
The Chamberlain model sold at Costco has close to a 10-ft track.
TTFN
Some people like these on fabricated structures because they don’t have to machine the mounting surfaces.
http://www.rollon.com/english/products/compact.htm
Barry1961
Your project sounds much like one I did. Weights, heights and travel very much similar. Our application was in an assembly line where a portion of the roller track needed to raise and lower.
We used a small self-contained hydraulic lift table which we anchored to the floor to control tipping from the extended track. We built it to lock the rollers when lifted and release when lowered so units could be moved down the line. The table with power unit weighed about 150 pounds and with the roller track installed maybe 350. Some of the weight was due to the roller lock system which added maybe 50 lbs.
Not real fast but cost less than $2500. There were some other features you may or may not need but this should give the general idea.
Griffy
I cannot tell if you are describing a chain fall operated Budget(r) hoist on a monorail or something more elaborate. Can you be more specific?
