Engineer In Training
My question is about EIT's job description in the workplace. It's been two years since i arrived in the US coming from the Philippines, and since then i've been working for an engineering firm in Galveston County, TX, and passed the EIT exam after that. I'm not really sure what an EIT is suppose to be doing aside from the general training idea behind it. Back in the Philippines we didn't have EIT programs set by the state so it's all relatively new to me. Most of what i do are:
1. Foundation design and analysis (includes footings, piles, belled piers)
2. General structural design (includes commercial, residential structures, silo structures, signage, renovations, composite design involving steel, concrete and timber)
3. Certified Residential Energy Inspector/Plans Examiner
4. On-site inspection of jobs
5. Drainage calculations for works in commercial and subdivision areas
6. Windstorm analysis on structures along and close to the coastal areas
7. Code interpretations for APA manuals, WFCM, ACI, AISC LRFD and ASD, IBC2003, IRC2003, ASCE 7-98, Fire Codes, Energy Codes
8. Residential HVAC load calculations
9. Complete architectural drafting and design (elevations, electrical, HVAC, floor plans, cross-sections, foundation layout, framing layout)
10. Spreadsheet construction for various structural and civil applications (includes structural steel beams, columns, connections, reinforced concrete retaining walls, foundation beams, shearwalls, pile and bored pile foundations, timber design, column interaction diagram for circular and rectangular RC columns)
11. Use of AutoCAD Land Desktop 2004, StaadPRO 2003, Archicad, RESCheck, ACECOMS softwares
Any input regarding the EIT's job description, I would appreciate it.
RE: Engineer In Training
My job description changed not a whit when I went from EIT to PE.
Hg
Eng-Tips policies: FAQ731-376
Richard A. Cornelius, P.E.
WWW.amlinereast.com
try 2nd paragraph, item 2
A few more years of 'apprenticeship' and you will get to sit for the national PE exam; appartently, you shouldn't have any problem with that test. Eventually, you will realize how very insignificant those two little letters behind your name really are~LOL.
Do yourself a favor and KNOW your state's code/law for practicing engineering. The easy part is getting the license; the harder part is keeping it!
Good luck.
"Eventually, you will realize how very insignificant those two little letters behind your name really are"
1.5 years ago I passed my PE, told my boss I wasn't making enough, demanded more, he refused, and I went elsewhere. I currently make between 44% and 76% more than I did then (I'm in land development, so OT and bonuses vary year to year). I do roughly the same amount and depth of work I did as an EIT...I respectfully submit that 'P' and 'E' are probably the most SIGNIFICANT two letters in my name.
I agree with HgTX and cvg, EIT's and PE's - in site/civil, anyway - do pretty much the same tasks.
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
Its basically in recognition of a person finishing their basic training and having enough experience to become fully productive and independent at work.
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
Same thing occurs in the UK and Australia as Chartered Engineer status is achieved.
The difference between an EIT and a P.Eng (or local equal status) is about $15,000 per year (or local currency equal)
