Generating core
Generating core
Generating core
We are working on a couple of intake manifolds, and I was wondering if there was an easy way to generate a core of one of the intake runners.  I don't need to generate a pattern from the piece at this time I just want to inspect the outer counters of the intake runner.  It is somewhat difficult after lofting and sectioning the part doesn't always work that well.
Perhaps there is a way to generate a negative image as that would work as well.
RE: Generating core
do a body substract from a solid chunk? (making sure the core volume can't touch the outer volume). Then a "delete body" for the outer volume.
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer/AI student
RE: Generating core
Interesting. I worked a bit on an intake manifold and we STARTED with the runners . . .winky smile
Hardie "Crashj" Johnson
SW 2005 SP 4.0 (reluctant to change)
Matrox Millenium G550
AMD Athalon 1.8 GHz 512 Meg RAM
