Element death APDL code
I'm trying to get element death to work in a loop to simulate a realistic failure.  Problem is, the ESEL and EKILL only seem to happen on the first loop iteration; after that the peripheral commands set to read the results set and solve continue to execute, but the ESEL and EKILL commands don't appear to execute whatsoever.  I did read chapter 12 on element birth and death (repeatedly) but as usual, I seem to be missing something (or the documentation does).  Here's the code.  Be kind, I'm no advanced programmer.
CODE
/SOLU
ANTYPE,0
ANTYPE,0
NLGEOM,1
NSUBST,rsn,0,0
OUTRES,ERASE
OUTRES,ALL,ALL
AUTOTS,0
LNSRCH,1
NEQIT,100
PSTRES,1
RESCONTRL,DEFINE,ALL,ALL,rsn
TIME,pressure
/STATUS,SOLU
SOLVE
FINISH
/REPLOT
*DO,I,1,rsn-1,1
     /POST1
    PLNSOL, U,Y, 0,1.0
    /WAIT,30
    /POST1
    SET,1,I,1,
    ETABLE,STRS,S,X
    ESEL,S,ETAB,STRS,SxMax
    ESEL,A,ETAB,STRS,-100000,SxMin
    ETABLE,STRS,S,Y
    ESEL,A,ETAB,STRS,SyMax
    ESEL,A,ETAB,STRS,-100000,SyMin
    ETABLE,STRS,S,Z
    ESEL,A,ETAB,STRS,SzMax
    ESEL,A,ETAB,STRS,-100000,SzMin
    ETABLE,STRS,S,XY
    ESEL,A,ETAB,STRS,SxyMax,,1
    ETABLE,STRS,S,YZ
    ESEL,A,ETAB,STRS,SyzMax,,1
    ETABLE,STRS,S,XZ
    ESEL,A,ETAB,STRS,SxzMax,,1
    ESEL,R,MAT,,1
    /SOLU
    EKILL,ALL
    ESEL,INVE
    ANTYPE,,REST,1,I,0
    RESCONTRL,DEFINE,ALL,ALL,I
    SOLVE
*ENDDO
RE: Element death APDL code
Although I don't really understand what you are doing with all this esel,,etab, I guess you should select all elements before you define your element table:
CODE
     /POST1
    PLNSOL, U,Y, 0,1.0
    /WAIT,30
    SET,1,I,1,
    esel,s,all
    ETABLE,STRS,S,X
If this don't work, perhaps you should explain how you defined SxMin, SyMin,...
In the end I would also select everything before solving:
[code]
    alls
    SOLVE
[code]
If you do that, you don't have to select all elements anymore before the etab comand.
Alex
Thanks for the comment Alex.  I don't think I can/should select all the elements before my esel & etable commands because the purpose of the commands is to select elements which have exceeded maximum stress values in order to kill them.  I notice that the selection and ekill routine works just fine the first time through the loop; but doesn't seem to work at all after that, so I'm inclined to think my problem has something to do with my restart or antype controls...
I will however try selecting all of the elements rather than my invert selection.  The more I think about it the more that sounds like the right approach.
The SxMin,... values are defined with simple SxMin=1000 type commands up in the program header.  I did it that way so others could easily modify the model without being code monkeys.
OK, tried the ALLSEL command before the solve, and still have the same problem; the element selection and ekill routine only runs the first time through.  After that its like its not even in the code.  Why would that happen?
Just to clarify, if I only run the loop once, making two SOLVE commands for the entire program, then the elements "die" as planned and the model reacts appropriately.  With more than two its asif I haven't changed anything from the initial solution. ???
Look at the stresses in the 2nd substep. I guess your selection bounds are wrong. Do the selection command by command an see what it hapens, if the elements are selected.
Alex
Even if the bounds are wrong (not sure why you say that), something should be happening which is different than running the solution without and elements killed, right?  I am getting some elements selected when I manually enter the code into the command line, as well as when I run the loop, but only the first time through in that case (I'm basing this on watching the output window).
If you could post an Ekill and restart routine even just selecting a particular element or volume for the kill, I think I'd get it from there in terms of adjusting my selection.  And thanks again for the HELP!
Here's the whole enchilada, if you wanna give it a try.  Insert some legal disclaimer here about not making a million bucks off this hacked together code.
CODE
!* Definition of variables ************************************************
tft=0.125        !top flange thickness
bft=0.125        !bottom flange thickness
fw=1.5            !flange width
ch=1.25            !core height
ra=50            !rib angle
rt=0.075        !rib thickness
ir=0.0625        !inside radius of the core
esf=.5            !element size factor
lat=.5            !load applicator thickness
pressure=100        !pressure applided to applicator - psi (must be an integer multiple of pinc)
pinc=50            !Pressure increment in results sets and solution
rsn=pressure/pinc    !number of results sets (and restart sets) to record
SxMax=4140        !Max Stresses
SyMax=160
SzMax=4140
SxMin=-4020
SyMin=-10000
SzMin=-4020
SxyMax=430        !Shear max stress values are absolute values
SyzMax=430
SxzMax=2850
ed=1            !extrusion depth
tl=.4            !multiplication factor for length of the target length beneath the core radius tl*(ir+rt)
/Title, True Failure
/NOPR
/PMETH,ON,0
KEYW,PR_SET,1
KEYW,PR_STRUC,1
KEYW,PR_THERM,0
KEYW,PR_FLUID,0
KEYW,PR_MULTI,0
/GO
/COM,
/COM,Preferences for GUI filtering have been set to display:
/COM,  Structural with p-Method elements
/PREP7
/COM, INPUT LINE INFORMATION FOR THE CORRUGATED SECTION
*AFUN,DEG               ! Units for angular functions are degrees
K    ,    1    ,    0.000    ,    bft                                    ,    0    ,
K    ,    2    ,    0.000    ,    bft+rt                                    ,    0    ,
K    ,    3    ,    (fw-TAN(ra/2)*(ir+rt)-TAN(ra/2)*(ir)-(ch-rt)/TAN(ra))/2+TAN(ra/2)*(ir)     ,    bft+rt    ,    0    ,
K    ,    4    ,    fw-(fw-TAN(ra/2)*(ir+rt)-TAN(ra/2)*(ir)-(ch-rt)/TAN(ra))/2-TAN(ra/2)*(ir+rt)    ,    ch+bft    ,    0    ,
K    ,    5    ,    fw    ,    ch+bft                                    ,    0    ,
K    ,    6    ,    fw    ,    ch-rt+bft                                ,    0    ,
K    ,    7    ,    fw-(fw-TAN(ra/2)*(ir+rt)-TAN(ra/2)*(ir)-(ch-rt)/TAN(ra))/2-(TAN(ra/2)*(ir))    ,    ch-rt+bft        ,    0    ,
K    ,    8    ,    fw-(fw-TAN(ra/2)*(ir+rt)-TAN(ra/2)*(ir)-(ch-rt)/TAN(ra))/2-TAN(ra/2)*(ir)-(ch-rt)/TAN(ra)    ,    bft    ,    0    ,
K    ,    9    ,    (fw-(fw-TAN(ra/2)*(ir+rt)-TAN(ra/2)*(ir)-(ch-rt)/TAN(ra))/2-TAN(ra/2)*(ir+rt))-tl*(ir+rt)    ,ch+bft    ,    0    ,
K    ,    10    ,    0.000    ,    ch+bft                                    ,    0    ,
K    ,    11    ,    0.000    ,    bft+ch+tft                                ,    0    ,
K    ,    12    ,    fw    ,    bft+ch+tft                                ,    0    ,
K    ,    13    ,    fw-(fw-TAN(ra/2)*(ir+rt)-TAN(ra/2)*(ir)-(ch-rt)/TAN(ra))/2-TAN(ra/2)*(ir)-(ch-rt)/TAN(ra)+tl*(ir+rt)    ,    bft    ,    0    ,
K    ,    14    ,    fw    ,    bft                                    ,    0    ,
K    ,    15    ,    fw    ,    0                                    ,    0    ,
K    ,    16    ,    0    ,    0    ,    0    ,
K    ,    17    ,    0.000    ,    bft+ch+tft+lat                                ,    0    ,
K    ,    18    ,    fw    ,    bft+ch+tft+lat                                ,    0    ,
/COM, LINES ARE CONNECTED BETWEEN KEYPOINTS LISTED BELOW
L,       1,       2
L,       2,       3
L,       3,       4
L,       4,       5
L,       5,       6
L,       6,       7
L,       7,       8
L,       8,       1
/COM, LINE FILLET FOR ALL THE CORNERS
LFILLT,2,3,ir, ,
LFILLT,6,7,ir, ,
LFILLT,3,4,ir+rt, ,
LFILLT,7,8,ir+rt, ,
/COM, INPUT LINES FOR FACES AND LOAD APPLICATOR
L,      24,       9
L,       9,      10
L,      10,      11
L,      11,       12
L,      12,      5
L,       5,     24
L,      26,      13
L,      13,      14
L,      14,      15
L,      15,      16
L,      16,       1
L,      11,      17
L,    17,     18
L,    18,    12
L,    19,    26
L,    20,    25
L,    22,    23
L,    24,    21
/COM, Define Element Types
ET,1,SOLID185
!KEYOPT,1,6,4
ET,2,CONTA173
/COM, Input Material Properties, #1 Orthotropic, #2 Isotropic
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,7E+005
MPDATA,EY,1,,7E+005
MPDATA,EZ,1,,70000
MPDATA,PRXY,1,,0.2
MPDATA,PRYZ,1,,0.2
MPDATA,PRXZ,1,,0.45
MPDATA,GXY,1,,78000
MPDATA,GYZ,1,,78000
MPDATA,GXZ,1,,295000
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,2,,29000000
MPDATA,PRXY,2,,0.26
/COM, Select areas
FLST,2,4,4
FITEM,2,16
FITEM,2,23
FITEM,2,24
FITEM,2,25
AL,P51X
FLST,2,6,4
FITEM,2,14
FITEM,2,15
FITEM,2,16
FITEM,2,17
FITEM,2,4
FITEM,2,13
AL,P51X
FLST,2,4,4
FITEM,2,6
FITEM,2,29
FITEM,2,4
FITEM,2,5
AL,P51X
FLST,2,4,4
FITEM,2,10
FITEM,2,28
FITEM,2,11
FITEM,2,29
AL,P51X
FLST,2,4,4
FITEM,2,7
FITEM,2,27
FITEM,2,3
FITEM,2,28
AL,P51X
FLST,2,4,4
FITEM,2,12
FITEM,2,26
FITEM,2,9
FITEM,2,27
AL,P51X
FLST,2,4,4
FITEM,2,8
FITEM,2,1
FITEM,2,2
FITEM,2,26
AL,P51X
FLST,2,6,4
FITEM,2,19
FITEM,2,20
FITEM,2,21
FITEM,2,22
FITEM,2,8
FITEM,2,18
AL,P51X
/COM, Extrude all areas to extrusion depth ed
FLST,2,8,5,ORDE,2
FITEM,2,1
FITEM,2,-8
VEXT,P51X, , ,0,0,-ed,,,,
/COM, Set Element Edge Sizes
!Rib
FLST,2,5,5,ORDE,5
FITEM,2,20
FITEM,2,24
FITEM,2,28
FITEM,2,32
FITEM,2,36
AESIZE,P51X,rt/5,
!flanges
FLST,5,12,4,ORDE,6
FITEM,5,30
FITEM,5,38
FITEM,5,-42
FITEM,5,67
FITEM,5,72
FITEM,5,-76
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1,tft/2, , , , , , ,1
!Through the depth
FLST,5,12,4,ORDE,12
FITEM,5,45
FITEM,5,-46
FITEM,5,50
FITEM,5,-51
FITEM,5,55
FITEM,5,-56
FITEM,5,60
FITEM,5,-61
FITEM,5,65
FITEM,5,-66
FITEM,5,70
FITEM,5,-71
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,ed*10, , , , ,1
/COM, Assign material properities
FLST,5,7,6,ORDE,2
FITEM,5,2
FITEM,5,-8
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT,       1, ,   1,       0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,VOLU
VSEL, , , ,       1
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT,       2, ,   1,       0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
/COM, Create Coordinate systems to align material properties
Local,11,0,0,0,0,25,0,0
!Lower Corner
Local,12,0,0,0,0,50,0,0
!Flat rib section
Local,13,0,0,0,0,25,0,0
!Upper Corner
/COM, Call the coordinate system and material properties for volume 6
TYPE,   1
MAT,       1
REAL,
ESYS,      11
SECNUM,
/COM, Mesh Volume 6 the lower corner
CM,_Y,VOLU
VSEL, , , ,       6
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/COM, Call the coordinate system and material properties for volume 5
TYPE,   1
MAT,       1
REAL,
ESYS,      12
SECNUM,
/COM, Mesh Volume 5 the flat rib section
CM,_Y,VOLU
VSEL, , , ,       5
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/COM, Call the coordinate system and material properties for volume 4
TYPE,   1
MAT,       1
REAL,
ESYS,      13
SECNUM,
/COM, Mesh Volume 4 the upper corner
CM,_Y,VOLU
VSEL, , , ,       4
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/COM, Call the coordinate system and material properties for the flat sections and sweep them
TYPE,   1
MAT,       1
REAL,
ESYS,      0
SECNUM,
FLST,5,4,6,ORDE,4
FITEM,5,2
FITEM,5,-3
FITEM,5,7
FITEM,5,-8
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/COM, Call the coordinate system and material properties for the load applicator and sweep it
TYPE,   1
MAT,       2
REAL,
ESYS,       0
SECNUM,
CM,_Y,VOLU
VSEL, , , ,       1
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/COM, Apply symmetry conditions
FLST,2,24,5,ORDE,17
FITEM,2,1
FITEM,2,-9
FITEM,2,11
FITEM,2,13
FITEM,2,-14
FITEM,2,16
FITEM,2,-17
FITEM,2,20
FITEM,2,23
FITEM,2,-24
FITEM,2,28
FITEM,2,32
FITEM,2,36
FITEM,2,38
FITEM,2,40
FITEM,2,42
FITEM,2,44
DA,P51X,SYMM
/COM, Apply zero bottom displacement
FLST,2,1,5,ORDE,1
FITEM,2,43
/GO
DA,P51X,UY,0
FLST,2,1,3,ORDE,1
FITEM,2,16
/GO
DK,P51X, ,0, ,0,UX,UY,UZ, , , ,
/COM, Apply Load to top
/PREP7
FLST,2,1,5,ORDE,1
FITEM,2,12
/GO
SFA,P51X,1,PRES,pressure
/COM, CONTACT PAIR CREATION - START
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
/GSAV,cwz,gsav,,temp
MP,MU,1,
MAT,1
MP,EMIS,1,7.88860905221e-031
R,3
REAL,3
ET,3,170
ET,4,174
R,3,,,1.0,0.1,0,
RMORE,,,1.0E20,0.0,1.0,
RMORE,0.0,0,1.0,,1.0,0.5
RMORE,0,1.0,1.0,0.0,,1.0
KEYOPT,4,4,0
KEYOPT,4,5,0
KEYOPT,4,7,0
KEYOPT,4,8,0
KEYOPT,4,9,0
KEYOPT,4,10,1
KEYOPT,4,11,0
KEYOPT,4,12,0
KEYOPT,4,2,0
KEYOPT,3,5,0
! Generate the target surface
ASEL,S,,,19
CM,_TARGET,AREA
TYPE,3
NSLA,S,1
ESLN,S,0
ESURF
CMSEL,S,_ELEMCM
! Generate the contact surface
ASEL,S,,,27
CM,_CONTACT,AREA
TYPE,4
NSLA,S,1
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,3
ESEL,A,TYPE,,4
ESEL,R,REAL,,3
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,3
ESEL,A,TYPE,,4
ESEL,R,REAL,,3
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
/COM, CONTACT PAIR CREATION - END
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0
MAT,1
R,4
REAL,4
ET,5,170
ET,6,174
KEYOPT,6,9,0
KEYOPT,6,10,1
R,4,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,45
CM,_TARGET,AREA
TYPE,5
NSLA,S,1
ESLN,S,0
ESURF
CMSEL,S,_ELEMCM
ASEL,S,,,33
CM,_CONTACT,AREA
TYPE,6
NSLA,S,1
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,5
ESEL,A,TYPE,,6
ESEL,R,REAL,,4
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,5
ESEL,A,TYPE,,6
ESEL,R,REAL,,4
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
FINISH
/SOLU
ANTYPE,0
ANTYPE,0
NLGEOM,1
NSUBST,rsn,0,0
OUTRES,ERASE
OUTRES,ALL,ALL
AUTOTS,0
LNSRCH,1
NEQIT,100
PSTRES,1
TIME,pressure
/STATUS,SOLU
SOLVE
FINISH
/REPLOT
*DO,I,1,rsn-1,1
     /POST1
    PLNSOL, U,Y, 0,1.0
    /WAIT,30
    /POST1
    SET,1,I,1,
    ETABLE,STRS,S,X
    ETABLE,STRS,S,Y
    ETABLE,STRS,S,Z
    ETABLE,STRS,S,XY
    ETABLE,STRS,S,YZ
    ETABLE,STRS,S,XZ
    ESEL,R,MAT,,1
    /SOLU
        EKILL,ALL
        ESEL,ALL
        ANTYPE,,REST,1,I,0
        RESCONTRL,DEFINE,ALL,ALL,rsn-I
        SOLVE
*ENDDO
FINISH
Sorry for length, but I'm not sure of how to post a file.
I begin to understand what your code do. But I think there a small error in it. It has to be:
CODE
ESEL,A,ETAB,STRSxy,SxyMax,,,1
ESEL,A,ETAB,STRSyz,SyzMax,,,1
ESEL,A,ETAB,STRSxz,SxzMax,,,1
instead of
CODE
ESEL,A,ETAB,STRSxy,SxyMax,,1
ESEL,A,ETAB,STRSyz,SyzMax,,1
ESEL,A,ETAB,STRSxz,SxzMax,,1
Is That correct ?
Second: I hope you are aware that etable works just for the selected elements. In the first do loop after
CODE
SET,1,I,1,
ETABLE,STRS,S,X
there are no elements selected. After that you define a new EMPTY table with:
CODE
ETABLE,STRS,S,Y
Is that what you want?
Nice catches!  Have adjusted accordingly.
Unfortunately, doesn't seem to get me any different results.  Here's what the loop looks like now.
CODE
*DO,I,1,rsn-1,1
     /POST1
    PLNSOL, U,Y, 0,1.0
    /WAIT,30
    SET,1,I,1,
    ETABLE,STRS,S,X
    ESEL,R,MAT,,1
    /SOLU
        EKILL,ALL
        ESEL,ALL
    /POST1
    ETABLE,STRS,S,Y
    ESEL,S,ETAB,STRS,SyMax
    ESEL,R,MAT,,1
    /SOLU
        EKILL,ALL
        ESEL,ALL
    /POST1
    ETABLE,STRS,S,Z
    ESEL,S,ETAB,STRS,SzMax
    ESEL,R,MAT,,1
    /SOLU
        EKILL,ALL
        ESEL,ALL
    /POST1
    ETABLE,STRS,S,XY
    ESEL,S,ETAB,STRS,SxyMax,,,1
    ESEL,R,MAT,,1
    /SOLU
        EKILL,ALL
        ESEL,ALL
    /POST1
    ETABLE,STRS,S,YZ
    ESEL,S,ETAB,STRS,SyzMax,,,1
    ESEL,R,MAT,,1
    /SOLU
        EKILL,ALL
        ESEL,ALL
    /POST1
    ETABLE,STRS,S,XZ
    ESEL,S,ETAB,STRS,SxzMax,,,1
    ESEL,R,MAT,,1
    /SOLU
        EKILL,ALL
        ESEL,ALL
        ANTYPE,,REST,1,I,0
        SOLVE
*ENDDO
