Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Just a quick note to say, "THANKS!" for these forums...The site is very well layed out and easy to use. Thanks for bringing us together - we need each other."
Geography
Mycroft (Marine/Ocean)
9 Jan 06 11:43
I am trying to source a way of connecting 19 sky + receivers to a multiswitch in Europe. The receivers require 2 coax feeds thus 38 outputs are required? I do not know of a switch that size and the correct way to connect the two lines from each receiver and thus require some help on possible switch solutions or cascading for success? Please advise the reason for two coax lines. I guess one is for HH and the other VH as the satellite is all digital in the high band?
Any and all help would be grately appreciated
Thank you
Mycroft
Higgler (Electrical)
20 Jan 06 13:01
The two polarizations let you double your channel numbers, hence one V and one H.
11.7 to 12.5 Ghz frequency (in Europe)will require some higher frequency coaxial switches.
I don't really understand your switch requirements clearly. If you have 38 ports and need to connect them to just one output port? If yes, then purchase four 1x10 coaxial switches and a 1x4 switch and connect together with rf cables, 40 inputs to 1 output result. Price would probably be $5K US range.
kch
Close Box
Join Eng-Tips® Today!
Join Us             Close
