shapes of superalloys in aircrafts
Hi, I need some info about which shape of nickel based superalloys used in aircrafts? :
1.Wire ?
2.Plates, sheet, strip and foil ?
3.Bars, rods and profiles ?
4.Tubes and pipes ?
Thank you
1.Wire ?
4.Tubes and pipes ?
Thank you
RE: shapes of superalloys in aircrafts
1. Fasteners (forged from wire)
2. Turbine blades (single crystal investment castings)
3. Compressor discs & shafts (hot forged from bar or billet)
4. Casings, rings, & seals (multiple production methods)
The following links have more information:
http://
http://www.thyssenkruppvdm.com/navi.31.htm
http://
http://www.nidi.org/
