INCOLOY 800HT
3
INCOLOY 800HT
INCOLOY 800HT
i WOULD LIKE TO KNOW THE MAXIMUM OPERATION TEMPERATURE FOR A PIPE OF INCOLOY 800HT
RE: INCOLOY 800HT
Look for ASTM B408, ASME SB-408 or UNS N08800.  The Young's modulus and S Stress values are published with suitable numbers to about 1100 degree F in Various ASME B31.1, B31.3, "Physical and Mechanical Properties".  The ASME Boiler and Pressure Vessel Code, Section II Materials, Part D - Properties - S values avalance down from 13000 psi at 1100 deg F to 2000 psi at 1300 deg F.  Thus, I would avoid N08800 above 1100 degree F.
John
RE: INCOLOY 800HT
See below for specific information on Incoloy 800;
http://www.specialmetals.com/
Suggest Incoloy 800 HT pipe/tube under ASME B 407.
Maximum service temperature depends on the application. For example,  Section I (boiler application) the maximum service temperature is 1500 deg F, where Section VIII, Div 1 application is 1650 deg F for unfired pressure vessels.
For B31 Pressure Piping (B31.1 - Power Piping) maximum service temperature is 1200 deg F. For B31.3 (Process Piping), the maximum service temperature is 1650 deg F.
RE: INCOLOY 800HT
Metengr,
The website link you provided has excellent information on it. Do you, or anyone else, know of a website with similar information for ferrous alloys, namely various grades of steel.  I have found the following website to be helpful.
http://www.steelforge.com/
Can someone recommend another website?  Thank you all!
RE: INCOLOY 800HT
Do any know the allowable stress for 1500°F to 1650°F for incoloy 800HT
RE: INCOLOY 800HT
Yes, per ASME B&PV Code, Section II, Part D, for UNS
08811, Incoloy 800HT
1500 deg F    2.2 Ksi
1550 deg F    1.6 Ksi
1600 deg F    1.2 Ksi
1650 deg F    0.91 Ksi
RE: INCOLOY 800HT
This allowable stresses aplyy to ASME B31.3 ?
RE: INCOLOY 800HT
No. For B31.3
1500 deg F 1.9 Ksi
1550       1.5
1600       1.2
1650       1.0
