Storage Tank Inerting Required?
I am working on a low presssure storage tank that will contain mostly water with some organic. Process simulation shows the vapor pressure of the organics is never quite enough to reach the lower explosive limit.
I think the tank should be inerted just in case, but I need to know if there are any codes or regulations to back my position? I have searched NFPA & API, but found no mention of this subject, so far.
R
R
RE: Storage Tank Inerting Required?
Visit thread798-76953 and thread378-91957.
While I understand the technical aspects of an explosive atmosphere, I am not so welll acquainted with the applicable codes and regulations, especially as concerns inerting.
I was hoping someone familiar with the codes could point me at sections that address use of an inert atmosphere.
R
