built-up section
built-up section
built-up section
When I try to calc the I in the steel manual I don't get close. I'm using the regular geometric formula's but I'm off. What would I be doing wrong.
RE: built-up section
Hi tolind
How about more information ?
regards desertfox
More info please. How do you know your number is off and by how much. Have you checked other sections to see if are still off.
I is Axd*2 plus Io for each component.
That's Area times d squares (distance from the neutral axis squared) plus moment of inertia about it's own NA.
Is that what you are doing?
