Working with Solids
Working with Solids
While working with solids I have hit a stumbling block. I have a complex piece that is off by one measurement of .187 in. I was wondering if there was a command I could use that would prevent me from starting this whole project over again.
RE: Working with Solids
if both solids to be unioned were dimensionally correct and the placement was also correct, why would there be any problem in the resulting union ?
If the model is off by any measurement, there are a couple of options to remedy the problem. You could use some of the solid editing commands to move or stretch a face. Or, you could create a new solid of the missing portion and union it to the main solid. This could be anything from a 30 second fix to an horu or two, depending upon the complexity of the model.
Sometimes, STRETCH will work like you'd expect it to on solids. Sometimes it won't. I have no idea why.
Failing that, some combination of the SLICE, COPY, MOVE, and UNION commands can probably help you adjust your object without regenerating it from scratch.
Mike Halloran
Pembroke Pines, FL, USA
