2 Questions at assembly level
Question 1:
I am working on a simple assembly of 2 components. One of the components is a sch80 pipe that I need to put a pipe tap hole in both sides. Is it possible to mirror the "Hole Wizard" feature to the other side. Keep in mind that I am working at the assembly level and not the part level. I do not want the hole to show up at the part level. I know I can just create the hole once on each side but for this part I would like to mirror it if possible.
Question 2:
In the assembly mode, is it possible to drill a hole through the wall of a pipe while specifying the end condition as the inside surface (basically an "up to next or up to surface" but those options are not available).
Suggestions welcomed,
Bloodclot
Question 2:
Bloodclot
Why do they put Braille dots on the keypad of the drive-up ATM?
RE: 2 Questions at assembly level
The reason may be because you will have a left hand thd.
Edit the sketch of the hole wizard feature and add another point. You will have two holes in the same skecth.
In an assy, you can take away mtl, but not add. In the hole wiz, just change the depth so it will not go thru.
Chris
Systems Analyst
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
2) Up to surface should be available (not up to next, limatation in my opinion) but specifying a depth as ctopher suggests may work better on a curved surface. What version of SolidWorks are you using?
I am using SW2006 SP2.0. The holes are on the same C/L so using a circular pattern won't work. Probably a limitation. I guess I know what my next SW enhancement request will be.
Bloodclot
A Circular Pattern is the only way (that I know of) to do what you are trying to do.
Perhaps we are missing something. Can you post an image of what you are trying to do. See FAQ559-1100, or FAQ559-1177 if you can post a zipped assy c/w parts.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
[img http://im
Bloodclot
Any reason why this can't be done at the part level? Then if you really wanted to, you could use the mirror function.
Bloodclot
CorBlimeyLimey
Your suggestion worked great. Thanks very much for your assistance.
Bloodclot
Yes. Just select the tapped hole feature in the FM tree & the axis (temporary or created) of the pipe, then Insert > Assy Feature > Circular Pattern & set the angle & number if instances.
