Part list questions
Part list questions
Part list questions
Parts List on NX2: is there a way to selectively hide rows? (and the corresponding balloon callout?)
Mostly what I want to show in my list is the assembly leaves, but there are a few higher levels I would also like to show. 'Edit levels' lets you show just leaves or top level only (etc) but is there a way to pick and choose the particular parts you want to call out?
RE: Part list questions
You can simply highlight the row and delete it.  The item numbers above it should update when the parts list is updated.
Works great, ewh, thanks for the tip.
On a related note, how do I add a part/row back after I have deleted it (undo is not an option since I have saved and reopened the part). Seems like this stuff would be in the help files but I can't seem to find it.
