Comparing Versions Of Different Files
Problem as follows;
We have up to 3 versions of the same files existing in 3 different project folders. When new projects were created I guess the folder was simply copied over to a new name. We now want to delete the multible versions and keep only one base version. We will then use the 'Searce Paths' in the Config.Pro to locate the files back in the original directory.
What is the easiest way to confirm that all versions are identical?
I know I can use the /Analysis/Compare Part/By Geom -By Feature but there are hundreds of parts, assemblies, drawings etc. It will take forever.
Also I was thinking of simply looking at the version number of the part,
( i.e. /File /Open/ Commands and settings / All Versions ) and if all the version numbers are the same then I can go ahead and delete.
Any Ideas or comments appreciated!
Cheers,
Speedy
![[banghead] banghead](https://www.tipmaster.com/images/banghead.gif)
Cheers,
Speedy
RE: Comparing Versions Of Different Files
Thanks for that. Yes I had already started to use windows search as this shows 'time/date of creation'.
It will take some time but worth it in the end.
Speedy
-Hora
