Touch circuit help needed
I am trying to find a circuit whereas you touch a piece of stainless steel and generate a 12 volt pulse that is sustained while the pad is being touched. I have circuits for one one touch and timed output, but I can't seem to find a circuit anywhere for what I described. Any help would be great. Thanks
RE: Touch circuit help needed
If you say you have some similar circuits (which must provide the "front end") why can't you just omit the flip-flop stage in the push-on push-off circuit, or the timer in the timed output pulse circuit?
http://www.touchsensor.com/faq.html
http://w
http://www.4qdtec.com/putpr.html
http://www.4qdtec.com/tchsw.html
