DeviceNet communications with Motoman NX controller
I am looking for any information on how to setup DeviceNet with the Motoman NX100 controller.  I have a micrologix 1500 plc as the master node using a 1769-SDN scanner.  Does anyone know where and how to map the data inside the NX100 controller?  I am using a pci devicenet card provided by Motoman inside the NX.  Any info would be helpful.  Thanks in advance.
RE: DeviceNet communications with Motoman NX controller
I just did an NX with RIO. I can send you the .pdf it may help
I figured it out.  Thanks anyway.
Curious about how you set-up the Anybus Devicenet with a 1769-SDN.  What were your input and output settings for the Anybus adapter in RSNetworx?  --5150
