Displaying system variables
I've figured out how to calculate the info I want by the use of a lisp file, but I can't get the info I want onto the drawing. I was planning on using a field to display a user variable (have the code written and all), but none of the user variables are available for display, and when I enter the code manually, I just get ####.
Is there any way to display the user variables (userr1, userr2, etc..) in a field like you would another system variable? Or is there another easy way to display the variables from a lisp file? Can I use a diesel function to display the variables?
RE: Displaying system variables
Display where?  In the drawing or on the command line?
To display the userr1 variable as plain text you could use something similar to this:
(defun c:sv2txt ()
  (setq txt (rtos (getvar "userr1")))
  (setq pt1 (getpoint "Pick start point for text: "))
    (command "text" pt1 "" "" txt "" "")
Note that the last line might need some massaging due to your current text style settings.
This won't autoupdate like a field would though. I don't know how to get a user variable into a field.
Can you give us a peek at your code? We are glad to help and give shortcuts when we know what's going on.
"Everybody is ignorant, only on different subjects." — Will Rogers
I'd put my code up, but it's just some really simple addition to the base variable that the user would enter. After thinking it over last night, I realized that it would really be best to forego the lispfile, and just not have the dims auto update fo r this application.
My original question still stands however, because I'm sure I'll want to apply this to another dwg. How do you display a sytem variable such as userr1 in autocad (preferably w/o a lispfile); and how do you display a variable from a lispfile in a dimension, textbox, attribute, etc.?
on the command line !userr1 will show it.
You can display the results by using RTEXT (remote text, Express Tools).  The diesel expression would be $(getvar, "userr1")
You can show the value of a lisp variable on the command line by using a leading exclamation point as IFR showed, but that doesn't work for a system variable.
Thanks Carl, that's exactly what I was looking for.
