Mirror Question (assembly mode)
Hello all,
I am working on a simple assembly of 2 components. One of the components is a sch80 pipe that I need to put a pipe tap hole in both sides. Is it possible to mirror the "Hole Wizard" feature to the other side. Keep in mind that I am working at the assembly level and not the part level. I do not want the hole to show up at the part level. I know I can just create the hole once on each side but for this part I would like to mirror it if possible.
Suggestions welcomed,
Bloodclot
Bloodclot
Why do they put Braille dots on the keypad of the drive-up ATM?
