Conversion formula for viscosity
 Can anyone give the conversion formula for viscosity - I need to convert Saybolt Second (SSU) to centi Stokes (cSt)? The actual value required is 100 SSU in cSt.
 I found some tables on the internet which give the conversion for selected values and also the following formula
 SSU = 4.55 * cSt, if cSt > 50.
 I would greatly appreciate if there is any analytical expression for this conversion.
Thanks in advance.
RE: Conversion formula for viscosity
Per Juvenal:
k.v. = 0.22 * S – 180/S
Where
k.v. is in cSt
S is in SUS
If you're dealing with anything above 100 SSU ~ 200cSt, the formula simplifies to k.v. ~ 0.22*S
Some parantheses for clarification:
k.v. = (0.22*S) – (180/S)
Typo correction:
"If you're dealing with anything above 100 SSU ~ 20cSt, the formula simplifies to k.v. ~ 0.22*S"
electricpete,
 thanks for the equation. the simplified equation you have mentioned k.v. ~ 0.22*S is the same as the ones I found at many websites and mentioned in the original post but in reverse as S = 4.55*k.v.
I was looking for a more general formula applicable over a wider range and I think I can you the one without simplification.
thanks.
You may use:
cS = 0.226 S - 195÷S for S < 100
cS = 0.22 S - 135÷S for S > 100
where S = SSU
thank you 23562
