Backpressure Valve Placement
We have a system which is using a positive displacement plunger pump to transfer silicone to our system. For these types of pumps, a backpressure valve is recommended. The outlet piping is 1/2 " Schedule 40 S.S. Would it make a difference if the valve is added closer to the pump or closer to the discharge vessel? The vessel is about 25 ft of piping away from the discharge of the pump.
Thanks.
Thanks.
RE: Backpressure Valve Placement
Regards checman
Rob B.
